Volumio und PeppyMeter
The following system I have:
Raspberry Pi 4 8GB
Argon Nanosound One (Raspberry Pi 4 DAC-Gehäuse)
Display: 7-Zoll-HDMI-LCD (H) Waveshare 1024 x 600
Volumio System-Version: 4.119
PeppyMeter Screensaver: 3.4.3
With the Volumio Versions 3.xx and PeppyMeter 2.2.1 everything worked fine.
I have now set up the system again and since then I have the following problems:
Volumio: When the Peppy Meter plugin starts, the 80s80s plugin gets stuck on the connected Waveshare display. Volumio keeps running, but the touch display can no longer be operated, only after a reboot. But this only happens with the 80s80s plugin, otherwise not. MP3s can also be played back with PeppyMeter, and other internet radios also work without issue with PeppyMeter.
Thank you all for your help.
Andreas
