Volumio turns off after startup
volumio turns off after startup
it starts up normally after connecting the power supply, first orange/green lights up then blue and turns off immediately, the control light does not light up…
power supply turns off then on and the same thing happens, no matter how many times I try
what happened before that was that I turned off (not restarted) the device with the volumio app.
Maybe it’s “stuck in”?
How can I bring it back to life? How can I possibly reset it?
Thanks in advance for your help!
Pali
Hello Pali,
Which is the product you are talking about?
Since you are a volumio product owner you are entitled of dedicated support service.
Please raise a ticket HERE attaching a short video showing the issue you encounter.
Best
Davide
VOLUMIO TECH SUPPORT
when the LED turns off right after becoming blue, it means the MCU firmware is being updated
when it happens, please wait some time without touching any button and without disconnecting the PSU, it should become active again after ~15/20 seconds
