Hello
I’ve seen sq change in last version of volumio (3.5.6.9)
Tidal sq has changed it was precise now it’s a king blocked song
Volumio using Tidal has now the best sq
Is it only me ?
Regards
Hello
Is it only me ?
Regards
Hello seems new change of SQ, Tidal connect is now on top, volumio using Tidal has not the best sq
For those who want to go to the limit and are using Tidal , Tidal connect is the way to go
Yes why wouldn’t you use Tidal connect app
Tidal FLAC is now enabled on native Tidal too
thanks !
