Volumio - Tidal and Bladelius ASK
I use the Volumio app with my Bladelius ASK - but I also have Tidal Connect via Airplay to the same unit.
When playing Tidal tracks with higher resolution than 16 bit 44 khz - the Volumio app displays 16 bit 44 khz. I can find the same track in my Tidal app, and play it - and the Tidal app displays the correct bitrate and sample freq.
But on the ASK - display it only states 16 bit 44 khz no matter what track with higher resolution I play.
Anyone know of this issue? Why doesn’t the Volumio app displays higher bitrates and sample frequency than 16 bit 44 khz…?
Hi @JarleJ
Try changing the Sound Quality setting for Tidal (Volumio Sources) to “High-Res”.
