When I play from a single album in TIDAL it stops playing through mconnect after one or two songs. Here`s the live log. I am not able to understand a thing. Maybe some of you guys can give me a hand.
Starting Live Log...
info: Upmpdcli Daemon Started
Generating RSA private key, 4096 bit long modulus (2 primes)
[2025-09-15 10:17:06] [connect] Successful connection
[2025-09-15 10:17:06] [connect] WebSocket Connection 127.0.0.1:3000 v-2 "WebSocket++/0.8.2" /socket.io/?EIO=4&transport=websocket&t=1757949426 101
error: Failed LSINFO: Error: [50@0] {lsinfo} No such directory
systemd-fsckd.service: Succeeded.
hwmon hwmon1: Voltage normalised
systemd-hostnamed.service: Succeeded.
info: [MyVolumio PluginManager] Adding plugin bluetooth to plan premium
info: [MyVolumio PluginManager] Adding plugin multiroom to plan premium
info: [MyVolumio PluginManager] Adding plugin metavolumio to plan premium
info: [MyVolumio PluginManager] Adding plugin manifestui to plan premium
info: [MyVolumio PluginManager] Adding plugin cd_controller to plan premium
info: [MyVolumio PluginManager] Adding plugin smart_inputs to plan premium
info: [MyVolumio PluginManager] Adding plugin hi_res_audio to plan premium
info: [MyVolumio PluginManager] Adding plugin tidal to plan premium
info: [MyVolumio PluginManager] Adding plugin qobuz to plan premium
info: [MyVolumio PluginManager] Adding plugin tidalconnect to plan premium
info: [MyVolumio PluginManager] Adding plugin qobuzconnect to plan premium
info: [MyVolumio PluginManager] Adding plugin bluetooth to plan superstar
info: [MyVolumio PluginManager] Adding plugin multiroom to plan superstar
info: [MyVolumio PluginManager] Adding plugin metavolumio to plan superstar
info: [MyVolumio PluginManager] Adding plugin manifestui to plan superstar
info: [MyVolumio PluginManager] Adding plugin cd_controller to plan superstar
info: [MyVolumio PluginManager] Adding plugin smart_inputs to plan superstar
info: [MyVolumio PluginManager] Adding plugin hi_res_audio to plan superstar
info: [MyVolumio PluginManager] Adding plugin tidal to plan superstar
info: [MyVolumio PluginManager] Adding plugin qobuz to plan superstar
info: [MyVolumio PluginManager] Adding plugin tidalconnect to plan superstar
info: [MyVolumio PluginManager] Adding plugin qobuzconnect to plan superstar
info: [MyVolumio PluginManager] Adding plugin bluetooth to plan virtuoso
info: [MyVolumio PluginManager] Adding plugin manifestui to plan virtuoso
info: [MyVolumio PluginManager] Adding plugin cd_controller to plan virtuoso
info: [MyVolumio PluginManager] Adding plugin tidal to plan virtuoso
info: [MyVolumio PluginManager] Adding plugin qobuz to plan virtuoso
info: [MyVolumio PluginManager] Adding plugin tidalconnect to plan virtuoso
info: Adding plugin bluetooth to MyMusic Plugins
info: Adding plugin multiroom to MyMusic Plugins
info: Adding plugin metavolumio to MyMusic Plugins
info: Adding plugin cd_controller to MyMusic Plugins
info: Adding plugin qobuzconnect to MyMusic Plugins
info: Adding plugin smart_inputs to MyMusic Plugins
info: Adding plugin tidalconnect to MyMusic Plugins
info: [MyVolumio PluginManager] Loading plugin "my_volumio"...
hwmon hwmon1: Undervoltage detected!
info: [MyVolumio PluginManager] MyVolumio plugin successfully loaded
info: [MyVolumio PluginManager] Starting plugin system_controller.my_volumio
info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
info: Starting MyVolumio Remote Streaming Endpoints
info: MyVolumio login type: Token
info: [MyVolumio PluginManager] MyVolumio plugin successfully started
info: [MyVolumio PluginManager] Loading plugin "streaming_services"...
info: Starting Streaming Service Transparent Proxy
info: [MyVolumio PluginManager] Streaming Services plugin successfully loaded
info: [MyVolumio PluginManager] Starting plugin music_service.streaming_services
info: Streaming services startup
info: Starting Streaming Daemon
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart volumio-streaming-daemon.service
info: [MyVolumio PluginManager] Streaming Services plugin successfully started
error: Cannot start Volumio Streaming Daemon
error: Failed initialization of streaming services: Error: Error: Command failed: /usr/bin/sudo systemctl restart volumio-streaming-daemon.service
Failed to restart volumio-streaming-daemon.service: Unit volumio-streaming-daemon.service not found.
info: MYVOLUMIO SUCCESSFULLY LOGGED IN
STREAMING PROXY: Starting server on port 3245
Node JS runtime: 14
info: MyVolumio token set successfully
info: MYVOLUMIO: Adding device
info: MYVOLUMIO: Evaluating Server
info: MyVolumio status changed
info: Removing browser output: myVolumio user plan is not superstar
info: Removing audio output:
info: Stoppping Tunnel 1
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl stop sshtunnel.service
info: Remote SSH Stopped
info: Setting Geolocation for MyVolumio to us1
info: Successfully Added MyVolumio device
info: Updating MyVolumio device info
info: Successfully Updated MyVolumio device
systemd-timedated.service: Succeeded.
info: CoreCommandRouter::executeOnPlugin: my_volumio , getAutoUpdateCheckEnabled
No test mode
No alpha test mode
info: CoreCommandRouter::executeOnPlugin: my_volumio , getAutoUpdateEnabled
info: Update Ready: {"changeLogLink":"","description":"You're already on the latest version","title":"No Updates Available","updateavailable":false}
info: CoreCommandRouter::executeOnPlugin: updater_comm , setUpdateMessageCache
info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getConfigParam
info: CoreCommandRouter::executeOnPlugin: appearance , getConfigParam
info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStatsObject
info: CoreCommandRouter::volumioGetBrowseSources
error: MyVolumio Plugin failed to authenticate in a timely fashion
info: Completed starting MyVolumio Plugin
e[34m [Metrics] e[39m CommandRouter: e[31m 46s 48.89ms e[39m
info: CoreCommandRouter::volumiosetStartupVolume
info: CoreCommandRouter::Close All Modals sent
info: CoreCommandRouter::executeOnPlugin: alsa_controller , checkAudioDeviceAvailable
info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2sStatus
info: CoreCommandRouter::executeOnPlugin: system , versionChangeDetect
e is 65537 (0x010001)
writing RSA key
info: BOOT COMPLETED
Soliciting pool server 200.160.7.186
Soliciting pool server 200.189.40.8
Soliciting pool server 200.160.0.8
Soliciting pool server 200.25.3.11
Soliciting pool server 200.25.3.17
Soliciting pool server 200.13.142.5
Soliciting pool server 162.159.200.1
Soliciting pool server 216.238.102.201
Soliciting pool server 200.160.7.196
Soliciting pool server 168.96.251.195
Soliciting pool server 66.231.64.28
Soliciting pool server 2a02:c6c1:156:283::21
info: Clearing queue after UPNP request
info: CoreStateMachine::ClearQueue
info: CoreStateMachine::stop
info: CorePlayQueue::clearPlayQueue
info: CorePlayQueue::saveQueue
info: CoreCommandRouter::volumioPushQueue
info:
---------------------------- MPD announces system playlist update
info: Ignoring MPD Status Update
info:
info:
error: updateQueue error: null
info: ------------------------------ 13ms
info: ------------------------------ 8ms
info: ------------------------------ 7ms
info: Starting UPNP Playback
info: Preparing playback through UPNP
info: CoreStateMachine::setConsumeUpdateService mpd
info:
info:
info:
info:
info: ------------------------------ 9ms
info: ------------------------------ 6ms
info:
info:
info: ------------------------------ 4ms
info:
info:
info:
info: ------------------------------ 5ms
info:
info:
info:
info: ------------------------------ 3ms
info:
info:
info:
info:
info:
info:
info: ------------------------------ 10ms
info:
---------------------------- MPD announces state update: player
info: ControllerMpd::getState
info:
info:
info:
info: sendMpdCommand status took 14 milliseconds
info: sendMpdCommand status took 12 milliseconds
info: sendMpdCommand status took 9 milliseconds
info:
info:
info: sendMpdCommand status took 22 milliseconds
info: sendMpdCommand playlistinfo took 17 milliseconds
info: sendMpdCommand playlistinfo took 16 milliseconds
info: sendMpdCommand playlistinfo took 14 milliseconds
info: sendMpdCommand status took 10 milliseconds
info: ControllerMpd::pushState
info: CoreStateMachine::syncState stateService play
info: CoreStateMachine::syncState currentStatus stop
info: CoreStateMachine::syncState currentStatus play
info: Received an update from plugin. extracting info from payload
info: CoreCommandRouter::executeOnPlugin: albumart , getAlbumArt
info: ------------------------------ 101ms
info: ------------------------------ 117ms
info: ------------------------------ 115ms
info: sendMpdCommand status took 89 milliseconds
info: sendMpdCommand playlistinfo took 81 milliseconds
info: sendMpdCommand playlistinfo took 75 milliseconds
info: ------------------------------ 163ms
info: ------------------------------ 146ms
info: CorePlayQueue::getQueue
info: sendMpdCommand playlistinfo took 70 milliseconds
info: ------------------------------ 187ms
info: Consume mode
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info: sendMpdCommand status took 6 milliseconds
info: sendMpdCommand status took 4 milliseconds
info: sendMpdCommand status took 3 milliseconds
info: sendMpdCommand playlistinfo took 3 milliseconds
info: sendMpdCommand playlistinfo took 4 milliseconds
info: ------------------------------ 77ms
info: ------------------------------ 76ms
info: Consume mode
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info:
info: ------------------------------ 75ms
