Volumio stops playing randomly after some time. I have to restart it again as a workaround, but it’s only a matter of time before it happens again. I’ve been looking at other issues raised in the forum and it seems this is a common and know issue, but without definitive fix so far. All the solutions I tried from other posts are not working (event factory reset).
Here is the error I can see when pressing play after it stopped:
failed to open alsa [alsa], Failed to open Alsa device “hw:5,0”: No such file or directory
Here is my setup:
Raspberry Pi 4 8gb
Volumio version: 2.868 (Experienced the issue with anterior version also)
USB DAC: Topping D50s
Please find below live logs I picked from volumio.local/dev
Starting Live Log…
info: CorePlayQueue::getQueue
info: CoreCommandRouter::executeOnPlugin: system , getHwuuid
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
info: Listing playlists
info: CoreCommandRouter::volumioReplaceandPlayItems
info: CoreStateMachine::ClearQueue
info: CoreStateMachine::stop
UNSET VOLATILE
info: CorePlayQueue::clearPlayQueue
info: CorePlayQueue::saveQueue
info: CoreCommandRouter::volumioPushQueue
info: CoreStateMachine::addQueueItems
info: CorePlayQueue::addQueueItems
info: Adding Item to queue: albums://Ella%20Fitzgerald/Ella%3A%20The%20Lost%20Berlin%20Tapes
info: Exploding uri albums://Ella%20Fitzgerald/Ella%3A%20The%20Lost%20Berlin%20Tapes in service mpd
info: CoreStateMachine::updateTrackBlock
info: CorePlayQueue::getTrackBlock
info: CoreCommandRouter::volumioPlay
UNSET VOLATILE
info: CoreStateMachine::play index 0
UNSET VOLATILE
info: CoreStateMachine::play index undefined
info: CoreStateMachine::startPlaybackTimer
info:
---------------------------- MPD announces system playlist update
info: Ignoring MPD Status Update
error: updateQueue error: null
info:
info: ------------------------------ 4ms
info: ------------------------------ 5ms
info:
---------------------------- MPD announces state update: player
info: ControllerMpd::getState
info:
info: ControllerMpd::pushState
info: CoreStateMachine::syncState stateService pause
info: CoreStateMachine::syncState currentStatus stop
info: ------------------------------ 20ms
info: ------------------------------ 22ms
