Just a question around OS selection for music playback. Does having the volumio os + squeezelite plugin defeats the purpose of having Volumio as an OS because one can just use any squeezelite distro out there.
From a technical perspective - is there any difference audio wise?
No, there’s no difference, since they use the same binary for playback. So yeah, installing the plug-in and only using that for playback (i.e. no playback via Volumio) does defeat the purpose soundwise.
However if you wish to use other plugins developed for Volumio… Then it doesn’t; e.g. the LCD plugin.
Thanks Saiyato for your reply. As you are the developer for the squeezelite plugin - will you be able to make it work with the spotify connect plugin? When i activate the squeezelite plugin - even spotify connect doesnt work.
The only way to listen to music through Volumio is to stop de squeezelite plugin. This is because the squeezelite process claims the soundcard. You might be able to work around it by fiddling with a sound.conf, making slave cards etc. but I must say, that is beyond me for now.
So in short, I can’t make it work right now, only you, by stopping the squeezelite plugin when switching to Spotify.
