Volumio Spotify playlists
Hello
Im using Spotify in my volumio and almost everthing works as expected. I can play songs and playlists in spotify without problems. Adding Spotify songs to volumio playlists works as well. But adding Spotify playlists to one of my existing volumio playlists doesn’t work. After adding I get the message that the playlist was added, but when I check the playlist it is still empty.
Any idea?
i have the same problem.
No one has an idea?
This is correct. You can view and play a playlist that you created in Spotify using the Volumio Spotify plugin, but you cannot edit the Spotify playlist from Volumio, nor can you add it to a Volumio playlist.
As I understand it, Volumio acts like a client, a window if you like, the two remain separate systems. A single track is fine, but a Spotify playlist is another database.
What I do in this case is to add the Spotify playlist to the Volumio queue, then save the queue as a playlist in Volumio (or adding it to an existing playlist)
Good tip!
