New Upgrade from 2.799
Installed Spotify Connect for Volumio2 - no problems. downloaded and setup user/password settings.
Volumio server not visible to native Spotify app without using Volumio Spotify Connect2 plugin
Trying to install and stalls at 10% download from URL:
http://plugins.volumio.org/plugins/volumio/armhf/music_service/volspotconnect2/volspotconnect2.zip
3 questions:
should I need to install both plugins
which is required if I want to connect with Spotify with their app and Volumio?
is the download not working? worked properly on last release.
There is a problem with downloading. Let me check…
just tried now and still seems not to be working…
Downloading plugin at http://plugins.volumio.org/plugins/volumio/armhf/music_service/volspotconnect2/volspotconnect2.zip
END DOWNLOAD: http://plugins.volumio.org/plugins/volumio/armhf/music_service/volspotconnect2/volspotconnect2.zip
Creating install location
Unpacking plugin
Checking for duplicate plugin
Copying plugin to location
Launching a bash shell
Installing volspotconnect2 dependencies
Detected cpu architecture as armv7l
Latest version: v0.2.1 Requested version: v0.2.1
Supported device (arch = armv7l), downloading required packages for vollibrespot v0.2.1
Downloading file
Plugin installation script failed!!
Why don’t you install it from Volumio via the plugin page?
Have you changed the default password?
Looks like the install script failed while fetching the release from github.
It could have been a network glitch - can you try again while tailing logs? (either from the /dev/
page using the Live Log
or via console with journalctl -f
I ended up following the manual installation instructions on the Github site. That all works fine installing to a RPI3B+ using SSH
thanks, here is the full log, looks like it downloads the main package but not the additional required libraries… (I changed http to **** to post this)
info: Downloading plugin at ****://plugins.volumio.org/plugins/volumio/armhf/music_service/volspotconnect2/volspotconnect2.zip
info: END DOWNLOAD: ****://plugins.volumio.org/plugins/volumio/armhf/music_service/volspotconnect2/volspotconnect2.zip
info: Folder /tmp/plugins removed
info: Checking if plugin already exists
info: Rename folder
info: Folder /tmp/downloaded_plugin.zip removed
info: Move to category
info: Checking if install.sh is present
info: Executing install.sh
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/sh /data/plugins/music_service/volspotconnect2/install.sh
info: Launching a bash shell
info: Installing volspotconnect2 dependencies
info: Detected cpu architecture as armv7l
info: Latest version: v0.2.1 Requested version: v0.2.1
info: Supported device (arch = armv7l), downloading required packages for vollibrespot v0.2.1
info: Downloading file
error: error
info: Plugin installation script failed!!
info: Install script return the error Error: Command failed: echo volumio | sudo -S sh /data/plugins/music_service/volspotconnect2/install.sh > /tmp/installog
[sudo] password for volumio: % Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 639 100 639 0 0 1425 0 --:--:-- --:--:-- --:--:-- 1423
0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:02 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:03 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:04 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:05 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:06 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:07 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:08 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:09 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:10 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:11 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:12 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:13 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:14 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:15 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:16 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:17 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:18 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:19 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:20 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:21 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:22 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:23 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:24 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:25 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:26 --:--:--
0
0 0 0 0 0 0 0 0 --:--:-- 0:00:27 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:28 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:29 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:30 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:31 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:32 --:--:-- 0curl: (7) Failed to connect to github-production-release-asset-2e65be.s3.amazonaws.com port 443: Connection timed out
info: An error occurred installing the plugin. Rolling back config
info: Plugin folders cleanup
info: Scanning into folder /volumio/app/plugins/
info: Scanning category audio_interface
info: Scanning category miscellanea
info: Scanning category music_service
info: Scanning category plugins.json
info: Scanning category system_controller
info: Scanning category user_interface
info: Scanning into folder /data/plugins/
info: Plugin folders cleanup completed
info: Error: Error
info: Folder /data/temp removed
error: error
error: error
error: error
error: error
error: error
error: error
Once again, can you tell me why you need to install the plugin using SSH instead of the plugin page of Volumio?
Looks like github is not not playing nice with you -
PS: you can wrap your stuff into code blocks (</>
symbol) to format it.
@balbuze Looks like @Aytek_Dorken is downloading it via the plugin installer, but @Travis_Tompkins manually installed it…
sorry missed your comment, I am trying to install from volumio web UI, not using SSH.
I actually don’t know how to install it via SSH.
What location are you trying this from?
Are you able to navigate to https://api.github.com/repos/ashthespy/vollibrespot/releases/tags/v0.2.1
from a device on the same network?
If you can get SSH access to your device , can you try running the following command to try and figure out why it’s failing?
curl https://api.github.com/repos/ashthespy/vollibrespot/releases/tags/v0.2.1
I am on the same network with my raspberry pi and I can navigate to the link you provided from my computer.
I will try to SSH to my device. How do I assign the SSH password to volumio?
the default password for volumio is “volumio”
irobot
December 13, 2020, 12:57am
16
Spotify Connect2 plugin still does not install. Fails every time doesn’t matter if installing from Volumio UI or via SSH. same issue as reported by @Aytek_Dorken .
RPi3b+ running Volumio v2.834.
Could you share some logs?
Either from the /dev
page using the livelog feature or via ssh .
# Volumio logs
journalctl -f
irobot
December 13, 2020, 5:12pm
18
Here you go.
</>Starting Live Log...
info: CorePlayQueue::getQueue
info: CoreCommandRouter::executeOnPlugin: system , getHwuuid
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
info: Listing playlists
info: CoreCommandRouter::executeOnPlugin: wizard , getShowWizard
info: CoreCommandRouter::executeOnPlugin: system , getShowWizard
info: Downloading plugin at http://plugins.volumio.org/plugins/volumio/armhf/music_service/volspotconnect2/volspotconnect2.zip
info: END DOWNLOAD: http://plugins.volumio.org/plugins/volumio/armhf/music_service/volspotconnect2/volspotconnect2.zip
info: Rename folder
pam_unix(sudo:auth): authentication failure; logname= uid=1000 euid=0 tty= ruser=volumio rhost= user=volumio
pam_unix(sudo:auth): conversation failed
pam_unix(sudo:auth): auth could not identify password for [volumio]
volumio : 1 incorrect password attempt ; TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/sh /data/plugins/music_service/volspotconnect2/install.sh
[sudo] password for volumio: Sorry, try again.
sudo: 1 incorrect password attempt
info: Error: Error
irobot:
Unfortunately, the plugin installer requires root privileges and as you have changed your password it will have trouble as it assumes the password is still the default one…
irobot
December 13, 2020, 5:39pm
20
Yeah I noticed that in the live log. what a bummer. why not simply prompt for password! does the plugin installer support such a function? assuming users will leave password to default is a bad assumption.
