Hi
since the last update the simple volumio equalizer plugin is not working anymore.
Can anybody confirm this?
Hi
Confirm… not working for me either…
Can’t play spotify
Can’t adjust volume .
Something about missing alsa file I think…
Did return to a older firmware and everything works…
Is it a fresh install or an update?
If an update, have you tried to remove the plugin, set correctly the output in Volumio ( to use it without equalizer) and when ok re-install the plugin?
Let me know.
It is an update.
After uninstalling the plugin, the sound worked again. After installing, it stopped working.
