Hi all,
totally noob here
I had to reflash volumio on my sd card as I’ve already done other times, now something went wrong.
It seems working properly but there’s no sound at all.
If it can help:
aplay -l
card 0: imxvt1613audio [imx-vt1613-audio], device 0: AC97-analog vt1613-hifi-analog-0
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: imxhdmisoc [imx-hdmi-soc], device 0: i.MX HDMI Audio Tx hdmi-hifi-0
Subdevices: 1/1
card 2: Audio [iFi (by AMR) HD USB Audio], device 0: USB Audio [USB Audio]
Subdevices: 1/1
cat mpd.conf
Volumio MPD Configuration File
Files and directories
music_directory “/var/lib/mpd/music”
playlist_directory “/var/lib/mpd/playlists”
db_file “/var/lib/mpd/tag_cache”
#log_file “/var/log/mpd/mpd.log”
#pid_file “/var/run/mpd/pid”
#state_file “/var/lib/mpd/state”
#sticker_file “/var/lib/mpd/sticker.sql”
General music daemon options
user “mpd”
group “audio”
bind_to_address “any”
#port “6600”
#log_level “default”
gapless_mp3_playback “no”
#save_absolute_paths_in_playlists “no”
#metadata_to_use “artist,album,title,track,name,genre,date,composer,performer,disc”
auto_update “yes”
#auto_update_depth “3”
Symbolic link behavior
follow_outside_symlinks “yes”
follow_inside_symlinks “yes”
Input
input {
plugin “curl”
proxy_user “user”
proxy_password “password”
Audio Output
resampler {
plugin “soxr”
quality “high”
threads “0”
audio_output {
type “alsa”
name “alsa”
device “hw:2,0”
dop “no”
audio_output {
type “fifo”
enabled “no”
name “multiroom”
path “/tmp/snapfifo”
format “44100:16:2”
#replaygain “album”
#replaygain_preamp “0”
volume_normalization “no”
MPD Internal Buffering
audio_buffer_size “8192”
buffer_before_play “10%”
Resource Limitations
#connection_timeout “60”
max_connections “20”
max_playlist_length “32384”
max_command_list_size “8192”
max_output_buffer_size “16384”
Character Encoding
filesystem_charset “UTF-8”
id3v1_encoding “UTF-8”
Thanks in advance
volumio
September 23, 2017, 3:16pm
2
Everything seems fine: output is set to your iFi DAC
