Installed the SDImage for Volumio 2 on a PI3… but even if the setup is not so difficult I have a strange and wired behaivour on the PI:
The Linux image looks quite poor… no raspi-config available and for those (me included) that are not so familiar with linux command, it is quite difficult to setup timezone, expand filesystem, setup the hostname…
Updating the system is a critical issue and I have problems in using apt-get update and upgrade that (both?!) result in an error
Plugins installation from UI also generates error (simply ends in error with no other explaination)
based on all this… my question is:
is PI3 fully compatible with Volumio2? would’t ne better to install jesse and install Volumio sources and recompile? (I’ve done this also but without a guide I got a non-working-and-pretty-unstable version )
Hi M, expanding the filesystem should happen automatically. You can edit the hostname in settings>system, not sure about date/time; must say I haven’t had much use for it. But you can edit that over SSH I think?
