I finished my Streamer-Dac.
I would like to introduce this.
RASPBERRY PI 3B +
PCM1794A DAC Board 192Khz/24bit
Allo Kali Reclocker Board
4.3" DSI Display
Linear power supplies
IR remote control
PeppyMeter screensaver
Transformers are individually manufactured.
Transformer for DAC Board: 230V AC/2x15V AC, and 1x9V AC
Transformer for RPI: 230V AC/1X9V AC/4A
In Volumio Setup:
The I2S DAC model: HifiBerry DAC
The Audio Resampling: 192Khz/24bit
The price of all parts is approximately: 460 Euro
You can choose another DAC too.
Allo Kali Reclocker is compatible with many other DAC chips
Copy the text to text editor, and save as the “.hex” extension. (For example: program.hex)
And with this file can you programming the PIC 12F675 Microcontroller.
(Programmers: PICKit3, PICKit4 or others)
If you select “I2S DAC” in the “Audio output” setting, you must select the type of “DAC Model”.
Here “PCM1794 DAC” type is not included. Therefore, I chose the “HiFerry Dac” option in the setting. This is also appropriate for PCM1794 DAC.
But the “Generic I2S DAC” choice is also appropriate.
The I2S signal from RPI goes to Kali Reclocker. KALI Reclocker generates a MCLK signal for PCM1794 DAC.
The MCLK signal is required for PCM1794 DAC. MCLK signal, RPI does not give out.
The I2S signal from KALI Reclocker goes to PCM1794 DAC. From PCM1794 to the analog audio output.
