Volumio Rivo plus as usb audio in for Nvidia Shield
When I do connect my Shield to my Rivo with an USB male to USB male cable, both devices are not seeing each other.
My goal: connecting both together with USB
Use Shield USB out
Use Rivo FusionDSP plugin (PEQ filters)
Use simple USB out to DAC
Is this in general possible?
What is required at Volumio side?
What is required at Nvidia side?
Looking forward to any news and information with high interest.
Thanks in advance for any message and/or reaction!
It’s not possible to use the Rivo plus as a peripheral of the Nvidia Shield.
You also risk of damaging your devices if you try to do so
Thanks. Do you know if this is possible witn some “converter” in between?
And is this hardware wise not possible, or software wise?
it is both HW wise and SW wise not possible
Thanks for your reply!
