Having trouble selecting a song from a playlist.
Im using the Tidal plug-in via Volumio phone app on Android
1 - it will always select a song 4 further-on in the list. i.e. if I want song 14 to play, I have to select song 10 .
2 - its very very slow
Anyone had this?
Hi Severian!
When you say you’re using the Tidal Plug-in, do you mean the native Tidal integration from within the Volumio interface?
Out of curiosity, have you tried opening a browser window on your computer or phone, typing in your rivo+'s local address (usually your ]“devicename.local”, or the device IP you can view in the network settings through the app), and validating wether or not the behavior repeats itself? Let the team know.
Hi, thanks for the reply - yes its the native integration.
Im not sure how Id replicate the behaviour by navigating to the device via browser, its only slow when selecting and playing songs
Hi @Severian
I just wanted to validate if the behavior is confined to the app, on your specific android device; if it’s a network issue, or if it’s the Rivo itself on any device that accesses it.
Also, as you’re a Rivo+ owner, you have can contact the Volumio Support team here:
https://volumio.atlassian.net/servicedesk/customer/portal/1/group/1/create/1
Hope this helps!
I see. Will try that thanks
