Hi! A bit frustrated. Bought European Streamer product of the year, RIVO!
The RIVO basics works, but still not able to login to MyVolumio and select plugins etc.
Login to Volumio account on web (here) is OK.
Login via rivo.local web server NOT ok.
Login via iOS Volumio app NOT ok.
I have heard that this is due to a known bug, but does anyone know when this fix will be released?
Hi, I understand your frustration with a lovely new streamer you can’t access. There’s no bug, but a config step or two. With your product you are entitled to free support. You can use the Volumio support desk for one-to-one help.
Nothing special (I think) in my home network. Rivo is connected to ASUS ZenWIFI ET12 router via ethernet, wifi is disabled on Rivo, other settings on Rivo under Functionalities Control than Tidal is set to off (I only play from Tidal or via local SSD with wav/FLAC files), firewall router has default settings (on). Playing music from Tidal via app or web rivo.local works nicely. Rivo is OTA updated to latest version.
1.Tried briefly to turn firewall off on router, but same error happens.
2.Tried a Factory reset via web interface and did a new install via web interface (used iOS app first time), but same error when I try to login to MyVolumio:
“Error. There is no user record corresponding to this identifier. The user may have been deleted”.
Enabled ssh so I can ssh into Rivo and do Linux cmd line for inspection. Nothing altered. Nothing that stands out in dmsg as I can see.
Strange and frustrating. What am I missing here?
My Rivo does not work as it should. I have a Samsung Galaxy tab 9+. In the Volumio app, when I play music in Tidal, it doesn’t play the song I tap on the screen. There are several songs in the list different from the song I pressed there. Does anyone here know how to solve this problem, thanks.
