I got a Volumio Primo from a friend and for my interesst I want to try some things with a standard OS.
I want to leave the OS as it is and try some things whicht cannot be done by volumio.
I inserted a SD-card, but the device starts without checking the bootable SD card.
Is it possible to set the boot order.
1st CD card
2nd the Volumio OS wherever it is.
When I remove the card it should start again with Volumio OS.
Thanks for any hints.
Thanks it works now, it is no Pi it is a Tinker Board.
I never said it was a PI, this extract is from the tinkerboard manual which you obviously did not read
Yes indeed, I realised it as I removed the device.
It is a hint, that Raspbian will not work.
Many thanks
For the Sabre DAC it is required a custom kernel driver, included in the Volumio image but not included in any other operating system.
The DAC can be found here:
it is also inserted.
this generic driver won’t work, as already mentioned it is required a custom driver that is not implemented in any other operating system rather than Volumio
It is a volumio-specific driver, built into the kernel for Volumio.
As @darmur wrote, the driver is not availlable for any other linux distribution. Unfortunately you will have to live with that.
the dtbo is the dt-overlay file, not the kernel driver.
the dtbo is useless if the linux kernel does not have the proper driver included
OK, than i will return to the original state.
One last thing, to be sure to get all connections correct.
Is there a wiring diagram for the Volumion Primo to the digital coax, antenna,
and the ground to be solderd?
Why that? You obviously already opened the box, then look at the wires and draw the diagram yourself.
Of course I opened it, I had to set the jumper as written above.
Every information is now found, I will flash it and I will have a better system.
Otherwise you can always install “Mountain Lion”
The hardware and Armbian works perfect, the kernel supports the DAC.
With Tinker OS it is waste of time.
Are you bumping your own topic?
Enjoy your experiment
