Does anyone compare Volumio Primo V2 vs Primare NP5 mk2?
Does anyone try the Primo or Rivo with the PD Creative power supply (the one usually used with Node 2i)?
Many thanks for your help.
Kind regards,
Eric
Kind regards,
Eric
Haven’t tried the primo v2 or np5 streamer
But use the primo hifi edition with a sbooster and the upgrade is actually ok not day and night but still worth it for sure.
If you need just a bridge than go for the rivo have not heard it but per info from local hifi store the rivo has more to give compare to np5
Best
