Hi, I switched off my Volumio Primo before the holiday. After arriving, I turned it on again, but Primo does not appear in the app. I have an hdmi cable connected and Primo boots correctly. Just don’t run in the Manifest environment.
Can I ask for advice and help with this?
Thank you
I already figured it out while browsing the forum here.
The problem was in the YouTube plugin.
Everything seems to be going well now.
Do I still need to uninstall the plugin?
Thank you for your help
The latest version resolves the issue you had. Just remember to restart your device after installing.
I shall release another version some time next week that is more fail-safe.
