Have anyone tried going from Primo hifi edition to the newer primo is it worth the switch?
As i see besides the design same dac chip used
But can see if the internal power implementation is the same
Hope some Volumio users reply on this
Hi Zojo,
the DAC part is extremely similar. However there are other differences which impact the overall result:
Hope that helps!
@volumio thx for your swift reply
Xlr’s i do not use only rca out
Will you recommend the swap from the hifi edition here or is the swap minor in quality of sound.
When you say network do you mean the wifi connex inside the Primo??
Or wired to
