Hi, Just booted up the latest Version of Volumio (3.423) and I can only see 1 plugin available (Fusion DSP). I can see installed plugins.
Was working fine yesterday.
Is it worth a factory reset to see if that fixes the problem ?
do you mean that this menu is missing?
please check if your device is listed on https://myvolumio.org/ and activated (if needed press the green play button)
Hi, found there were 2 devices of the same name on myVolumio website. I have deleted one of those.
The menus have now reappeared on reboot.
Thank you for your assistance.
