Hi Dear friends;
I did a Volumio computer with the Asrock J4105B-ITX motherboard using the Volumio pc software. But this motherboard does not have M.2 2230 Wifi slot, I have tried a very usb wifi modul but wifi did not work … What can I do?
do you know how many different usb wifi modules are out there?
Why not make it easier and give us brand/model :mrgreen:
I have two motherboards. One of Asrock J4105B and J4105. asrock J4105 M.2 with wifit slot. I’m currently experimenting with the Intel 9260NGW NGFF 2.4G / 5Ghz 802.11ac Wifi Blutooth 5.0 1730Mbps but it doesn’t work …
Yes it is a known issue with newer hardware for the official x86 version, nothing that can be done about it (the kernel is too old and we decided not to update).
We have a new beta release coming soon, based on Debian stretch, which will use kernel 4.19 LTS.
In the meantime I recommend to try the last dev version
It has a mainline kernel, is very usable and confirmed stable by a number of people, but does not have all the latest bells&whistles (like myVolumio).
Flash the referenced version and give me a short feedback, AFAIK it already supports i219-v.
