Hi all,
Sorry to make my first post a help and support one, but I am excited to get Volumio running and seem to be stuck and unable to find the answers searching around!
My issue fundamentally is that Volumio, current V3.757 and also V2.777 tried, simply does not seem to boot up.
I am using:
Raspberry Pi5 2GB with 4A power supply
PimoRoni NVMe base
Kingston NV2 NVMe PCIe 4.0 500GB
SanDisk 64GB Endurance Class 10 SD card
However, even at its simplest, of just the Raspberry Pi5 and Power supply with the SD card, I am not getting a boot.
What I do not have is a Micro HDMI cable, so my confirmation of successful boot relies on visibility of the device over the network, however I note that although the on-board LED changes from Red to Green, it does not begin flashing.
When I create the SD card, I am using the Volumio .img file from this official site and selecting a custom image to load from the Raspberry Pi Imager software. In the extracted files from this site are also a .md5 file, which I am not making use of.
I am quite confident of all of the hardware and that the SD card itself if not a problem, because I have done the following with complete success using Raspbian OS:
Boot from Raspbian SD card.
Make the NVMe visible (enable PCIe etc.).
Use Imager from within Rasbian OS to load Rasbian to the NVMe and boot successfully from that memory device with SD card removed.
Of course, I then copied the Volumio .img file to Raspbian OS running on the SD card, so I could use imager within the OS in the same way to load Volumio to NVMe. This appeared successful, with files visibly copied over and validation completing. Still, it does not boot.
Lacking a direct display connection, this is done using Angry IP scanner initially to find the device on my network, it is connected by Ethernet which I can be confident works well since this has all worked with Raspbian. I can then use PuTTy to enable VNC and subsequently use the device with a GUI over RealVNC.
No keyboard is connected either, I don’t expect any of that is an issue for an OS designed to run headless though.
It seems as though I am failing very early on here with Volumio, but feel confident in all my hardware, so hopefully once this initial issue is resolved I can carry on with the project smoothly ![]()
Any guidance welcomed!
