Hi all
I have a raspberry Pi 1 version B and cant select a static IP address as well as a custom name.
If I just choose the name it is stable, if I just choose the static IP it is stable, but if I have both options on, it stops responding on the network.
I tried several versions since 2632 to 2729 with no avail.
Is there anyone still using RP1?
Thank you!
It is a much nicer experience with one of the later RPis.
