I am trying to use Volumio with a Raspad 3(pi4) and cant get sound output. The list of plugins is hugh. Any ideas which one to use?
are you using a dac on you raspad 3?.. i would try the 3,5 headphone jack on the pi
and not on the other board maybe then you get sound or over hdmi.
for volumio on your screen i would use the touch display plugin.
No dac, just updated to volumio 3 and it fixed it! Thanks!!! BTW, sound on the Raspad is horrible!!!
a dac will improve the sound quality a lot, the output on 3,5 mini jack is bad.
You’re using the internal speakers or connected the 3,5mm cinch to an amplifier?
