Hi. Is a Pi. Zero W enough to run Volumio plus OpenVPN as client. All I use is Spotify and using 3.5mm jack. Will this run without issue please?
AndyW
Not sure about OpenVPN, but I run Volumio on a pi zero w. It runs mostly just fine. It takes a while to index your songs when you plug in a USB, and isn’t as responsive as you’d like sometimes, but for the most part it works just fine.
That’s cool. I don’t have local music. Purely Spotify. I can configure OpenVPN in the CLI no problems. As long as Spotify can run on a Pi Zero W I’m golden.
Thanks for the reply
