The volume on this can’t be adjusted in the webui. If I go into settings and set the mixer to software after that the whole thing stops functioning. Until I reboot Volumio is unresponsive, meaning the webui has a circle in the center that rotates (if you will). If I reboot, the settings are back to “non” for mixer. Trying again results in the same issue.
Aside from that it sounds OK when played with “out of the box” settings, albeit with much a higher volume which made me want to figure out how to reduce the volume without having to reduce the volume on the stereo.
One other comment. I don’t get Volumio. It plays music from my library or some other source. I thought it had a Sonos like feature where I could play the same song on multiple devices that are running Volumio also. Is this the case? I didn’t find it featured in the interface.
Any thoughts?
