Hello I am running on Volumio version2.348. I am getting no response when I try to update using the ‘Check Updates’ button in the GUI, even though version 2.368 is available for download.
Does anyone else have this problem?
Thanks.
Have the same problem trying to upgrade from 2.362. Is there a way to upgrade with a command line via SSH?
I had the same problem on the Touchscreen GUI.
I got no responce when I clicked on the “Check for Updates” Button on the touchscreen.
Then I tried it with my smartphone (Sony Z3) and Chrome browser… and here, it works…
When I had trouble updating, they had me go into network settings and set up custom DNS settings, with 8.8.8.8 in the primary box and 8.8.4.4 in the secondary box. It was several updates ago, but it fixed my problem.
Enabled wireless, had it disabled for some reason, and update is now working. And so is searching for plugins and radiostations, both dysfunctional with wireless disabled.
