I have a raspberry pi 4 and am trying to install Volumio on it. I have flashed the latest Volumio software using Balena Etcher (onto a USB Drive) and plugged that into the RPi. I have plugged in an ethernet and then power just to get things setup (im hoping to use just wifi on the long run). Unfortunately I do not think Volumio is booting. I cannot access Volumio.local/ and have tried android, Mac and windows devices. I also cannot see a Volumio hotspot on any devices.
Is Volumio compatible with the Raspberry Pi model B? It seems many others have managed to get this working.
If anyone has any suggestions or has managed to get Volumio working on an RPi 4 model B please let me know!
will do, but have to buy some micro sd as all mine are in phones. Can I use it as music storage as well as a boot drive or is that impossible?
Might be possible through a partition…
volumio uses the whole sd with 3 partitions on it you could use the sd as volumio and as storage, usb or a powered external drive or a network drive you can pick what you like …
