Hi, I have a question about installing volumio on raspberry pi 4. When I create an sd card on the PC with Raspberry pi imager and I downloaded volumio from the official website, then I insert the card into the raspberry, which is connected to the TV with a micro hdmi cable, and it comes out like this in the pictures. When I press ESC as it says, I enter the diagnostic mode and there I see that the card is recognized. and I don’t understand the rest. The same thing happens when I set the system to boot from a USB stick. We have a solution for this problem, the system is the newest that exists on the site.
did you apply any customization to the image, before writing to the SD-card?
if yes,please flash the image again on the SD-card, pressing “NO” to the request of applying custom settings
furthermore, boot from USB does not work with the latest stable image, we’re working to implement that feature
I did not make any adjustments to the clean install.
do you have another SD-card to try?
I tried with a usb stick and the same thing happens. I have not tried another sd card.
please read what I wrote before
USB will not work anyhow, because USB boot it’s not implemented yet in the latest stable release
I managed to replace the sd card.
does it work?
Yes man
