Volumio 4.119, Pi 3B, IQAudio DAC.
Volumio insists upon auto-mounting a USB drive to the path /media/drivename with the user and group both set to “root”. This prevents adding or updating the USB disk’s directories and music files from another computer across the LAN because of the error: “Could not create directory: Received error SSH_FX_PERMISSION_DENIED with description ‘Permission denied’”. Filezilla can only be logged in as the user “volumio”, not as “root”. Also, you cannot change the ownership of the mounted directory using SSH (eg with PuTTY, sudo chown) because you cannot log in as the user “root” either (only as “volumio”). The auto-mount and its restrictions seem to be the result of a change made in the newer versions of Volumio. Is there a way to remount the USB drive path with the owner and group set to “volumio”?
Wheaten
September 14, 2026, 12:59pm
2
I think it’s this issue, reported 4 months ago.
opened 05:03PM - 09 May 26 UTC
Tested with with V4.119 and V4.139., on to systems Dell Wyse 3040 and Dell Wyse … 5070.
Both act the same and very issue is reproduceable.
Took a fresh install, ran intial setup and installed FusionDSP.
At this point everything looks normal.
<img width="616" height="126" alt="Image" src="https://github.com/user-attachments/assets/eae9d792-6355-44fc-abe9-a9bdd33deb8f" />
As soon as I connect a USB3 HDD, the ownership of /data/INTERNAL changes to root, causing the plugins to break.
<img width="631" height="152" alt="Image" src="https://github.com/user-attachments/assets/b067f5d9-582a-400f-96d7-0f76d63c21eb" />
On Top, new installed plugins are not installed on the Volumio drive, but to the removal harddisk. So unplugging the harddisk all content of /data/INTERNAL is gone.
Log without HDD. Owner of /data/INTERNAL/FusionDsp = volumio
[http://logs.volumio.org/volumio/aBJwTHj.html](http://logs.volumio.org/volumio/aBJwTHj.html)
Connect HDD:
Owner of /data/INTERNAL/. = root
[http://logs.volumio.org/volumio/TOcOs1o.html](http://logs.volumio.org/volumio/TOcOs1o.html)
In my case, volumio is installed on sdb.
The logs shows that when I connect the external drive sda, it's reffered to as sdb, which doesn't make sense, as sdb is the drive where Volumio has been installed.
May 09 16:04:13 wyse-5070 kernel: usb 2-1.4: new SuperSpeed USB device number 5 using xhci_hcd
May 09 16:04:13 wyse-5070 kernel: usb 2-1.4: New USB device found, idVendor=0bc2, idProduct=2344, bcdDevice= 7.12
May 09 16:04:13 wyse-5070 kernel: usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
May 09 16:04:13 wyse-5070 kernel: usb 2-1.4: Product: Portable
May 09 16:04:13 wyse-5070 kernel: usb 2-1.4: Manufacturer: Seagate
May 09 16:04:13 wyse-5070 kernel: usb 2-1.4: SerialNumber: NT36K1C0
May 09 16:04:13 wyse-5070 kernel: scsi host1: uas
May 09 16:04:13 wyse-5070 kernel: scsi 1:0:0:0: Direct-Access Seagate Portable 0712 PQ: 0 ANSI: 6
May 09 16:04:13 wyse-5070 kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
May 09 16:04:18 wyse-5070 kernel: sd 1:0:0:0: [sdb] 9767541167 512-byte logical blocks: (5.00 TB/4.55 TiB)
May 09 16:04:18 wyse-5070 kernel: sd 1:0:0:0: [sdb] 4096-byte physical blocks
May 09 16:04:18 wyse-5070 kernel: sd 1:0:0:0: [sdb] Write Protect is off
May 09 16:04:18 wyse-5070 kernel: sd 1:0:0:0: [sdb] Mode Sense: 53 00 00 08
May 09 16:04:18 wyse-5070 kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
May 09 16:04:18 wyse-5070 kernel: sd 1:0:0:0: [sdb] Preferred minimum I/O size 4096 bytes
May 09 16:04:18 wyse-5070 kernel: sd 1:0:0:0: [sdb] Optimal transfer size 33553920 bytes not a multiple of preferred minimum block size (4096 bytes)
volumio@wyse-5070:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 1.1G 0 loop /static
sda 8:0 0 4.5T 0 disk
|-sda1 8:1 0 16M 0 part
`-sda2 8:2 0 4.5T 0 part /data/INTERNAL
/data/INTERNAL
sdb 8:16 0 119.2G 0 disk
|-sdb1 8:17 0 366M 0 part /boot
|-sdb2 8:18 0 5.3G 0 part /imgpart
`-sdb3 8:19 0 113.6G 0 part
mmcblk0 179:0 0 29.1G 0 disk
|-mmcblk0p1 179:1 0 366M 0 part
|-mmcblk0p2 179:2 0 5.3G 0 part
`-mmcblk0p3 179:3 0 23.4G 0 part
mmcblk0boot0 179:256 0 4M 1 disk
mmcblk0boot1 179:512 0 4M 1 disk
sudo blkid
/dev/sdb1: LABEL_FATBOOT="boot" LABEL="boot" UUID="5B77-2931" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="primary" PARTUUID="64ce5572-3829-42e5-a8ba-b3efc9d78e76"
/dev/sdb2: LABEL="volumio" UUID="c8a76367-25e9-4f88-b69e-1eeb27baaa50" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="primary" PARTUUID="042de68f-7cbd-41d1-9fe5-7f75b1794d7f"
/dev/sdb3: LABEL="volumio_data" UUID="34871b73-980b-4279-816d-5d22bb30cbef" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="primary" PARTUUID="499ed1b9-33b6-4881-bc50-10af25f532dc"
/dev/mmcblk0p3: LABEL="volumio_data" UUID="970ff7f3-d192-4dba-8562-04b1e572d7b6" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="primary" PARTUUID="1b79bcf6-c3fd-4795-8b52-05ec142b6455"
/dev/mmcblk0p1: LABEL_FATBOOT="boot" LABEL="boot" UUID="0129-261A" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="primary" PARTUUID="4c346e40-6770-4810-a5a1-29ac6332ecac"
/dev/mmcblk0p2: LABEL="volumio" UUID="5815d0ea-f56a-4b5e-98b8-22435cac99fc" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="primary" PARTUUID="a4132d92-ce83-4a43-845c-825e27b0b656"
/dev/loop0: TYPE="squashfs"
/dev/sda2: LABEL="ihdd" UUID="E066-707B" BLOCK_SIZE="512" TYPE="exfat" PARTLABEL="Basic data partition" PARTUUID="6a679aaf-a5e5-4f5b-a3c0-94668f334571"
/dev/sda1: PARTLABEL="Microsoft reserved partition" PARTUUID="70eea388-7c2f-4dfa-80fc-038f1b371f77"
Thanks. It’s an ownership issue and with the owner being set to “root” one cannot simply change the ownership. Not even using sudo permissions.
Wheaten
September 14, 2026, 2:10pm
4
I expect the USB drive is formatted as exfat?
if yes then a temp bypass is given in my previous post.
