Thanks for this, I was hoping there was a good native iOS app to control Volumio! As great as the web interface is, a native app is almost always preferable.
Hey, the app looks great! I only have one issue, due to my network I can only access volumio via specifying my specific IP address. A manual IP address input to select a player would be greatly appreciated.
Congrats for this awesome work. It is so nice to use this on the iPhone than the web page. Keep up the great work.
I am very happy with this development great work! It is a sign of success in your corporate world.
Finally tested it and confirm it works.
Would it be possible to add side scrolling to the next test flight release?
This feature is really helpful fro browsing through large libraries.
Just wanted to mention a bug that makes it crash.
I’ve added a web radio to a new playlist : when I try to open this playlist, the app crashes.
Actually, when I verified the playlist with the WebUI, it contains an empty line…
It seems that creating a playlist with a web radio isn’t possible yet with Volumio : too bad for those who want to wake up with a radio
nice App! Thanks a lot for it. It’s much faster, than using the webclient on my iPhone and that’s really cool.
Just a little issue: I have two volumio instances running in my home. Currently I have two different links on my iPhones Home Screen.
It would be nice, to be able to switch easily between different instances on the first / start-screen of your app. With your app I wasn’t able at all to switch between them. My impression is, that your control under ‘Change Player’ isn’t able to display them both. It finds the first one and that’s it.
you really did a great job making this app. It’s by far the most comfortable way to use Volumio. The problem I am seeing here might not be in your app but I hope you might be the one to know about it.
System: Raspberry Pi 1 Model B+ with HiFiberry DAC+ / iPhone6 with latest Rev of the app / FW: volumio 2.114 updated to 2.118
Setup after installation: fixed IP, added some radio stations, localized language, enabled the DAC - that’s all.
Problem: After power up + boot the app does not connect to Volumio (name and fixed IP are OK, Port is 3000). However it is possible to call and use the GUI from my PC. Once this has been done, the app will connect too and can be used as expected.
Do you have any advice how to troubleshoot this problem?
Further I would like to add an item to your feature request list:
I would like to have some kind of a default starter that will run after opening the app.
It should provide default settings for every choice the user normally has to take and ends up with a running radio station or playlist.
In short: Click the app and listen to the music.
You may want to try with a newly flashed image of 2.118: indded OTA upgrades between those versions encountered several networking issues due to underlying OS changes that do not come with OTA upgrades. You may want to confirm your issues with an new image.
your advice was extremely useful. There is obviously some difference between an updated version of 2.118 and the entirely new build download.
With a sd card flashed from the download my problems are gone.
To the maintainers: It is very useful to alter the Rev.No. even when changes are small because changes simply change things - at least for some of us.
