I would proudly take a beta testing task, too
-Stephan
-Stephan
Send me a PM with your iTunes account email!
Hi there,
so far this is really a great app and it works pretty well.
I noticed that when navigating to āWeb Radioā -> āMy Web Radioā all my āstationsā are listed as folders (which when navigated to are empty). Shoutcast stations are displayed correctly.
Cheers,
cgtobi
Hi cgtobi,
iāll fix it in the next build, thanks for your feedback
Hey monkeyproof,
thanks for adding me to the Beta.
There I realized that the app is iOS 10 only. I have an iPhone 4s, so iām stuck with iOS 9.
Will the iOS 10 dependency be permanent, or is it possible to add support for iOS 9 at a later time?
Greetings
Zapp!
Hi Zapp,
Unfortunately seems Apple is releasing a new version of itās coding language on every iOS update. I didnāt tried to build for Swift 2, but i can make a tentative one of these days [emoji6]
I expected something like that.
Thank you for your work!
I use Volumio everyday and I would love to test your app.
I canāt sent PMās as Iām new in the forum. Can you please send me a PM and Iāll reply with my iTunes E-mail?
Fast progress update
Hi guys,
iāve been quite busy in the past few weeks, but there are some huge improvements iām going to release soon.
Thanks for all of you are actively supporting me testing the app.
Since today we have 15 testers, 334 sessions and only 8 crash!
Itās a great result for a project started just 2 months ago
Stay tuned!
PS: Iām going to submit this new version to the AppStore before the end of the year if there arenāt big issues!!!
Now we are 16 testers
Iāve tested the app today and I found one āissueā. āOne click volume stepsā option doesnāt came from Volumioās configuration. Your default (5) is to much for my setup. If you canāt read the value at least give us the option so change it in settings.
Thereās also a cool feature that I would love to have. Locked screen widget so we can stop or adjust the volume without unlock the phone and search for the app.
By the way, nice design! Keep up the good work.
Thank you for your feedback!
From the next build there is a simple slider to input the volume level. Itās not so simple to increase/decrease of a single unit, but i can work on it.
Great idea the widget
Hey,
I am following this thread since I registered for this forum now. It seems that (unlike the Android app), the IOS Version is much more advanced. Good job!
Currently I have some questions:
Does your application support several Volumios ? (I currently have 3 of them running in different rooms)
My girlfriend (she is an IPhone User) struggles with the Web UI, hence I would like to ask, how stable your build is. She only needs volume control, start stop and browsing of the media library. Maybe your app can help her and improve the acceptance of what I set up
Many Thanks for your work!!!
Bests,
shaDN
Hi shaDN,
right now you can choose which Volumio use by switching it from settings. Itās a āliveā selection, so you donāt need to do nothing more of selecting one of the reachable ones. Iām working to insert a switch option even in the playback screen using a tab-like interaction.
The beta out for test is really stable, just 8 crash over 380 session, but iām going to release a new one before the end of the day and since there are lots of changes, i canāt be totally confident with it :mrgreen:
If she find tricky to use the app, she can always come back to the web uiā¦but iām sure she wonāt
That sounds pretty cool. What do you need, to make her one of your beta-testers?
Bests,
shaDN
Send me a PM with the iTunes account email
v 1.0 (12)
Hey there Monkeyproof. Your app looks great, and I would like to be a beta tester too. Iām a new user, so I canāt pm you. Can you pm me? I saw a another guy had the same problem earlier in the postā¦
Wow, monkeyproof, did nāt expect the next version to be such a great improvement, nice work!
I really like the the action bar.
The volume adjustment works.
Clear queue bug has gone, confirmed.
Transitions between browse sections working good.
I think that you are not far away from final version, perhaps we can consider this version GM?
Hi Mark,
thanks for all your feedbacks, they helped me a lot!
We can definitely say this is the GM! Iāll wait just a couple of day to let you use it and discover any bad issue, after that iāll send the app to Apple for approval
Adding web radios doesnāt seem to work with the new version (tap, double tap or swipe).
PS: The new volume control is awesome
