Is the analog input of Volumio Integro integrated in Volumio Software as if it was a file playable from HDD library.
More specifically, if I connect an Analog Source on this, will it be processed by the plugins (FusionDsp, PeppyMeter, and so on)?
Another question, where can one test this equipment in Portugal?
Thanks for your quick answer. If possible, in future implementations, make two analog inputs or one but switchable between pass / not pass through Volumio system.
The reason I needed that was to use FusionDSP for roomcorrection in analog inputs also.
