So im trying to install Volumio on my RPI Zero W (first one).
It has been working before, but i cant get it to start. It just initiates a shutdown after booting up for the first time. I used the official raspberry pi imager. I tried plugging in a screen and pressed esc on the splash screen and from that i cant really tell much
did you download the official image from volumio.com or did you use the one provided by raspberry imager? The latter is a know way to get into troubles.
Apparently there is some unpacking done in the background with the cache file. If I flash the cache file myself it burns the unzipped files to the SD (*.img + *.md5)
Raspberry Imager streams the local cache file on the fly and decompress as it goes, while flashing the *.img file it’s block-by-block.
Renaming lastdownload.cache to lastdownload.cache.img.xz and unpack it, it reveals the same file
