Thanks to Miero, we now have a test build of Volumio2 for BeagleBone Black:
Feedbacks are greatly appreciated:
updates.volumio.org/bbb/volumio/ … bb.img.zip
Please use updated image for BBB: updates.volumio.org/bbb/volumio/ … bb.img.zip
Works great!
One issue I noticed: connected USB (self-powered Hard drive) and its not recognized\mounted (EXFAT)
do we have the exfat module in the kernel?
IMHO exfat is not kernel module, but a library for fuse. At least in the standard kernel.
The fuse is supported in that kernel. I’ve successfully created and mounted exfat filesystem on my Debian based image.
Are exfat-fuse and exfat-utils installed on the Volumio?
Will this image work on another I2S DAC besides Botic?
Booted my BBB from microsd with updated image and runs beautifully (Thank you miero and michelangelo)
Had same issue, tried to connect USB drive via powered USB hub but not recognized/mounted.
Have so far connected it to 2 USB DAC’s and both worked perfectly (ifi micro IDAC2 and Yamaha A-U671). Will have an I2S DAC I can try it with sometime today hopefully.
Happy to help with testing if/as needed
Same problem here, can enable i2S on Beaglebone Green on Volumio 2, please help
Do you have any information about new Volumio image for Beaglebone Black?
