I have a problem with a project with volumio and maybe here i can find help.
I run volumio, Ver. 2.x, on a Raspberry Pi 3B+. The Hifiberry Amp2 is connected to the Pi.
I connected the Hifiberry with the Pi via short Jumper wire cables.
Also, there is a Waveshare-Display (13.3 inch) connected to the display.
Everything runs fine.
I also run a python script which runs a motor on the device.
The motor has ist own power supply, so that it is not powered by the pi.
When i run music after the startup, before i run the motor, theres sound/ music.
It works. But when i than start the motor, the sound stops and doesnt come back.
When, after starting the pi, i first run the motor and then play music, theres no sound.
Volumio shows that music is played, but there is no sound.
I first powered the Pi via the Hifiberry amp2. After i recognized the problem, i drove the pi with an own power supply and the Hifiberry Amp2 with an own powersupply. I removed the 5V and 3.3V connections between the Pi and the hifiberry, to prevent a problem from this.
Everything works like before, but still the exact same problem.
I use none of this GPIOs, that are needed from the Hifiberry, for the motor:
From Hifiberry:
“GPIO2-3 (pins 3 and 5) are used by our products for configuration. If you are experienced with I2C, you might add other slave devices. If you a a novice, we don’t recommend this at all.
GPIOs 18-21 (pins 12, 35, 38 and 40) are used for the sound interface. You can’t use these for any other purpose.
GPIO4 is used to control the MUTE function of the power stage. Pulling it to low will mute the output.”
They are all connected from the Pi to the Hifiberry.
Does anyone have an Idea?
After the two seperate power supplys didn’t solve the problem, my only idea right now, is to avoid the problem in the way, that i would start volumio with a delay.
That doesnt solve the problem, but would avoid it, as most time i would only need the motor in the beginning after the start of the pi.
Does anyone know if ist possible to start volumio with a delay?
Best way for me would be with a python script.
Or does anyone maybe have a “real solution” to the problem?
(I also looked if a gpio plugin could solve my problem in some way, but i dont think so. Maybe theres one i havent found yet that could help.)
Thanks a lot in advance!
