Last night I carried out a fresh install of Volumio and every this worked perfectly. This morning Volumio wont stream to my DAC - please see the attached image & the log, can anyone suggest the cause and a cure?
http://logs.volumio.org/volumio/1KBvTsc.html
Stupid question but … did you select the correct input on your DAC ?
First power on your DAC, select the right input (I2S).
Than powerup Volumio.
First of all, stop opening new topics for the same issue. Keep them combined to one.
People will stop responding this way.
The log shows that the DAC isn’t detected:
# sudo i2cdetect -y 1 ---------------
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
# aplay -l ---------------
card 0: vc4hdmi0 [vc4-hdmi-0], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: vc4hdmi1 [vc4-hdmi-1], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
Subdevices: 1/1
/boot/config.txt:
dtoverlay=hifiberry-digi
So either your DAC has an HW error, or as @Kingpin states,
make sure the DAC is powered before booting Volumio.
Final and last, as I am repeating myself to you.
Solve you power issue first.
Again the log has 7 entries with:
hwmon hwmon3: Undervoltage detected!
The rPi will reduce it’s resources and everything can go wrong. (read become unstable, act unexpected)
Thanks - I think that I’ve identified the cause but I need to run Volumio over the next day to confirm
So, the problems continue - no sign of voltage issue, sat between the PI 5 & the DAC is an LHY filter board, the Pi & the DAC take their power via the GPIO pins - music ‘skips or constantly drops out’ when played, the applies to music played via USB in to my CXN-100 and skips via the DAC. Every thing works well for a few hours and then the problems set in.
Please don’t post logs under this topic and change your DAC, This is costing me valuable time to sort out.
- Uninstall MPD_OLED. This plugin can cause these kind of side effects under certain circumstances.
- Disable Multiroom (Under Sources)
- Disable Startup sound (Under System)
Reboot and see if it solved your problem.
