Hello, after almost 2 years it starts with this message, no boot. There were no installations, no changes, just normal perfect work with brilliant sound.
It needed much effort to tune display, vu meter, all stations and all is gone now
I would not advice to clone this one. You will also clone errors and end up with an unstable system.
Do a fresh install on a new SD and you can create a backup after installation with win32diskimager.
Try to get a small class 10 SD, so you donāt end up with a huge backup file.
Thank you Wheaten, I have another card, even with version 3, but after starting to play music it does very loud boom from speakers and I am afraid to use it, maybe you have an idea how to fix it, if possible, does it also for you ?
No, loud booms are not suppose to happen. I have 8 devices and none of them do āBoomā.
Please post a log when this is happening, something is wrong but hard to guess.
And mention your used hardware:
