please config.txt for 4K tv philips?
Welcome Modest Alexandrovich,
you have to tell us more about your set up is it a x86, rpi ect.
raspberry pi 4
вообще ничего не показывает по тв!
translation from post above:
nothing at all on TV!
use the first hdmi port and sometimes it helps to install Touch Display plugin
Set in /boot/userconfig.txt:
disable_overscan=1
hdmi_group=2
hdmi_mode=87
hdmi_cvt 1920 1080 60 3 0 0 0
hdmi_drive=2
hdmi_enable_4kp60=1
if you don’t want to force 60hz you could remove the 4k60 line and replace it with
framebuffer_width=1920
framebuffer_height=1080
@gvolt did i do this right ?
English please.
[Google translate]
are the black lines normal ?
no way to remove them?
do you still have the 4k60 line in it? i have to ask but the guy that is good with displays isn’t here right now.
check if the cables are seated good
please post type of the philips 4k screen maybe a setting isn’t right.
i set this framebuffer_width=1920
the cables fit well!
Resolution: 3840x2160px
Ultra HD (UHD) / 4K / 2160p"
Matrix: IPS
Backlight: Direct LED
Brightness: 400 cd/m2
Viewing angles (horizontal / vertical): 178° / 178°
Max refresh rate: 60Hz
this is above what i know you have to wait till gvolt can pick this up.
OK thank you very much
installed like this
disable_overscan=1
hdmi_group=2
hdmi_mode=82
hdmi_drive=2
still black bars
set it back to the old one but wait till gvolt can anwser on this don’t leave it connected for now to be safe.
is your screen normal on a other device?
You can use the tvservice application on the command line to determine which modes are supported by your device, along with other useful data:
tvservice -l
is used for display id
tvservice -s
displays the current HDMI status, including mode and resolution
tvservice -m CEA
lists all supported CEA modes
tvservice -m DMT
lists all supported DMT modes
can you give the results of this ?
The black lines could be due to a bad cable. Have you got another cable to try?
