A new image of Volumio for Rasberry Pi has been released, the news are described here: http://wp.me/p44hxy-fD
Since this is a really experimental version, I really would like to know your feedbacks, like what doesn’t work and what is improved since the 1.1 version. Thank you!
Here are some issues I have found with beta 1.2 (RPI, Volumio beta 1.2, USB DAC with CM6631A, USB Wifi, external power supply, all connected together before power on, web access through MS WIn 7 IE8 and Chrome):
I can’t connect using wifi only for the first time. I was scanning IP adresses in my network byt Volumio wasn’t connected. So I needed to connect using Ethernet, configure Wifi and I can unplug Ethernet then. Even after restart I can use wifi only now
I still have an issue with USB DAC (CM6631A driver). Volumio web interface only offers ALSA. I need to reboot it and I can see audio (USB output them)
I can’t connect to Web GUI with Wifi connection only - I need to do SSH, restart MPD - /etc/init.d/mpd restart and I can connect via web GUI then. However if I have ethernet cable connected I can get to web GUI without any issues
If I remember correctly I have seen these 3 issues with beta 1.1 as well.
If I do all above steps it works very fine but I can´t power of RPI. Otherwise I need to always restart MPD to have web gui available and reboot volumio to see my USB DAC.
Hi there. Just registered to let you guys know that /var/log/php_errors.log is filling up the sdcard in 1.2beta. It also happens if you do an “apt-get upgrade” on 1.1. I think php5 has been recently updated and causes this. I don’t know php, so i can’t help with a fix!
Today, version 1.2 is installed, use (item.taobao.com/item.htm?spm=a1z … 5269012142) This es9023 board i2s connection skins, sounds good, faster than the 1.1 start version of the fast, smooth to operate than the original, thanks developers Michelangelo.
I have the RPi connected via P5 to a Buffalo DAC. It looks like it works faster and smoother than the previous release, but I still get horrible pops between one track and the other. I tried the CFix, but with no improvement.
Any suggestion what to work on to make some tests ?
Thanks Michelangelo for updating this great development!
I’ve tried it out today, but unfortunately after unplugging ethernet cable, I do not get connection through wifi anymore, wlan does not work.
With version 1.1 this problem doesn’t occure. Has anybody made similar experience and are there any hints to get a solution?
I’ll give it some more starts now, maybe I’m lucky
The power save setting does not help. I notice the in app setup adds that. I usually setup my wifi manually on PI’s. It seems the UI and the backend is doing something on startup as it works but then drops out on a reboot. Where does volumio store its internal configs? It does seem to read the system settings for wifi consistently?
this version is quite a lot better than 1.1 probably because so far i have yet heard any crack noise playing music.
the web interface is quite responsive and there is not sluggishness as in the previous version
one thing is that in my first installation, it was not able to recognize my DAC. also, i could not get the web interface up on browser after changing a few settings. it didnt help even on cold boot. I had to install it for the second time in order to bring the web interface up and this time, it could see my DAC.
Just an update: playing 16/44 material is fine with no crack noise. However, it is not the case playing 24/96 music files. Occasional cracks noise does appear but less frequent than version 1.1
With respect to the Wifi issue, I had issue with Wifi without Ethernet coupled, not connecting. I then changed my IP Wifi setting in “/Interfaces” from static into DHCP, and it works!
Also had issue with connecting with the NAS, but could solve it with the MKDIR-statements of Onholysmoke (thanks)
No other tweaks.
Having done that, it just works GREAT! No clicks and most of all, no echo anymore with piano or guitar. Man, I am happy with this.
