Volumio for PCM 1791 DAC and PGA 4311 volume control
Hi everyone!
Im working on my degree project with Volumio, (i m already install all plugins like spotify soundcloud and so on and connect my Raspberry Pi zero 2W with my dac PCM 1791, but no signal on output of my DAC) and my question is which of all DAC models is best working with yours dacs cause a lot of DAC support I2S 24bit MSB first standard. And also im asking if is needed to configure something else in my Volumio or just connect three wires and everything is on Volumio itself because sometimes volumio freeze for long time (5minutes) and i must reboot it. and when i choose one of DACs Volumio show me this error message {Failed to open “alsa” (alsa); Failed to open ALSA device “volumio”: No such device}. So i was trying to set up normally output of my RPi for my DAC but i thing model Zero 2 W is not very stabile for music output
(and my aplay -l is here)
card 0: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
So i need to figure out of my setup to connect volumio DAC output of my RPi to my PCM 1791.
I also asking if is there plugin for external volume control using SPI peripheral for my PGA 4311 volume controller.
Thank you all, and have a nice day!
MLiska.
