I would like to have the option to install Volumio on normal PCs.
Can someone create a port of it?
Hi try this two options:
install a debian linux on a pc and then do the steps listed in this tutorial:
typingoutloud.org/raspberry-pi-i … io-pibang/
worked great for me on a gigabyte brix -
go to
download the image and put it on a usb
Then do the 4 easy installation steps and then configure the rest through its web ui
i am currently listing to an old celeron laptop that plays through an pro ject s usb dac
Works great as well.
Both solutions will play bit perfect if you configure it so.
