I haven’t used Volumio for a long while, but since a few months I’ve tried again, unfortunately without success.
What I have done:
Currently the SD card has a Volumio 3.324 download from August 2022, maybe not the latest but that doesn’t have to be the problem. At the end of August, this version was also not working.
An SSD drive with 5GB of music is also connected. As a DAC I use an iFi Nano DAC.
What does work:
The configuration page of my modem/router gives an IP address:
Thank for both answers but the result is the same: Can’t open the page because the server doesn’t react. This message is from my iPhone with the Safari browser. With Google and Firefox it’s the same. Although I know the IP-address it will not open Volumio.
I did a scan with the app Net Analyzer and it also did find Volumio on the network but that’s all.
Hello DVO,
I think I did use it for the last time in the beginning of 2021. In August I downloaded on the SD_card Volumio again, version 3. I did it the same way as the newest Quick-Start-Guide shows. In my home I’ve got only one network. I can see Volumio on my desktop in network and on my iPad/Phone using the app Network Analyzer.
So far as i see 2021 august is the 2.xx version (2.915)
And the new version of 3.xx can have some burning issues
I advice to try burning it with win32diskimager And see if it makes a difference.
It was August 2022 and it is version 3.324 (using SD Card Formatter and balenaEtcher) as you can see in my first message. but of course I can try it with Win32 Disk Imager.
So I will try again
First I did format the SD-card with updated SD-card formatter, a quick format. Downloaded Volumio for Rasp.Pi. But now I have two image files:
Which one to install???
And Win32 Disk Imager doesn’t see these files at all in my downloads, so for me useless.
Just used Balena Etcher with the Windows.IsoFile first. Now Balena Etcher did choose the image.
Did install the card in Rasp.Pi. Wait and see… after 10 minutes Volumio has an IP-address and shows up in my Network.
In my case, Balena Etcher was a bit easier, especially when it picked the right file on its own.
And I didn’t know what an MD5 was at all, very confusing that Volumio doesn’t say anything about it or I didn’t see something.
By the way, thank you for your attention .
Well they do mention it, sort of:
The MD5, is just a hash signature of the file which you can verify. In this case you know that what you have downloaded is actually the original file as posted by Volumio.
If they had it should be on this page. Besides, even Google doesn’t understand what a hash signature is, some kind of cannabis quality? MD5, kind of Russian missile?
And, yes the file is only 1Kb, so that could help choosing right.
But Volumio could have done it something like this:
