I have two pendrives connected.
Total 362 albums. When I enter a collection of music, Volumio does not show all the covers. Each album has a file called cover.jpg or cover.png smaller than 1mb, mainly 300x300px.
Volumio does not show me random album covers, mainly those at the end. Is there a limit? When I clear the cache album the problem appears on the second pendrive. The problem is changing one on the first memory later on the other.
Memory cleaning in firefox does not help.
Similarly, when I enter albums in the tab. There are no covers for what are in the collection of music. It’s like it’s random.
And every folder with the album has cover.jpg. I do not understand.
I will be grateful for every hint.
in log: An internal error occurred while serving an albumart. Details: Error: ENOSPC: no space left on device,
1,6 GB is free but loop0 is 100% full, is this a problem?
I checked the card on the laptop
all graphics are stored in “overlay” and are saved there, but volumio does not display them via www, 8mb is free, why this partition has only 274 mb when mmcblk0p2 has more than 1gb free and only kernel file on it
something does not work as it should
edit///
the problem is probably solved. I installed volumio on sd 16gb and everything is shown even pictures of artists and I did not have them before.
The problem returned on the 16gb card.
I have a message that there is no free space after apt-get update.
I know where the problem is.
Installation on linux by the ether program - the problem is in the partition created by the installer - volumio_data
Volumio_data is too small and additionally the installer does not allocate a free space partition.
After installation, there is approximately 12 gb of unallocated space on the 16gb card.
The solution is to manually resize the volumio_data partition and assign it the rest of the free space. - gparted
Volumio ayuda para ver las imágenes incrustadas en el archivo.
Buenas tengo una duda para ver si alguien me puede ayudar, estuve leyendo artículos de la Comunidad y buscando un montón de información para intentar resolver un problema con el visionado de la caratula del disco que se encuentra incrustado como metadato.
Yo clasifico la información de una manera un particular, para ver mi Biblioteca musical en un reproductor de música n7player (una aplicación de Android) que tiene una forma de visualizar la Biblioteca musical que a mí me gusta mucho.
Una vez dicho esto, yo edito los metadatos con un programa que se llama TagScanner. Y en general me funciona muy bien, yo veo la carátula que yo incrusto en todo tipo de reproductores desde ipod a reproductores de coches, en la aplicación recomendada por BLISS, también muy bien salvo algún fallo puntual.
Sin embargo en Volumio ( mi configuración es unaRapsberry Pi 3B con una DAC de Suptronics X900) configuración que copie de Youtuber italiano (Gianluca Bocci). No tengo ni idea de Linux y la verdad que su video y la traducción Beta de Google, me ayudo mucho a descrubir Volumio.
Volumio me encanta, salvo el hecho de no poder ver las caratulas tal y como expliqué, estuve mirando unas páginas pero ocurre que mi Ingles es limitado, y la traducción de Google a veces no es suficiente. Encontre Github (que no se bien lo que es ) y encontré una cosa que se llaman strings en i18n DE CARLOS PÉREZ y tiene un comando “METADATA_ IMAGE” (estuve peleando con un programa Putty), para intentar introducir eso en la imagen ISO del Volumio.
En definitiva no tengo idea y por eso solicito si alguien me puede ayudar a que el Volumio muestre la imagen incrustada en el archivo. (La solución de una imagen cover en la carpeta no es viable, tengo casi 8.000 pistas muchos singles).
GRACIAS.
