Volumio Debian Buster Beta - Raspi images debugging
Ok, it ís ok now with me.
One problem : v3.15 can not scan usb music file, please check it or tell me what I can fix it!
V3.14 scan well.
Thank you very much!
Mac
Hi !
Ok no problem ,
So you can show me some advice for scan from usb music file??
I try do for fix it,
Thank your advice!
Mac
First:
I think volumio should switch to names instead of numbers in selecting audio device.
“hw0,1” can change sometimes, but “plughw:sndrpihifiberry” is always the same i think.
Second:
What about device browsing in 3.15?
Third:
Bullseye is not so far away, maybe wait until it is released and switch directly from 7 to 11 :wink:
Greetings guys,
  1. This is a Volumio BE issue, and is being tackled separately :slight_smile: I’ve been focusing more on the Build system and getting working Buster images…
  2. Have some hunches about this, still have to confirm the fix…
  3. Bulleseye is still a few months away (hard freeze scheduled for 2021-03-12), the upgrade to it should be less painful that our current 7-10 jump :wink:
Thank you so much…
Still searching for building armv8 :
on the github link you provided to me,
it talks about armv8 switch: does it work with pi switch? Are they still working on it?
Like I said, it’s not going to work out of the box like that – you will have to tinker with the scripts to pick the right kernel and userspace…
Should i test/try something to help?
I’m a bit preoccupied for the next few days, but the plan is to switch from the old node v8 to a much more recent node v14, once we have new builds for that, will update you! :slight_smile:
I can’t use airplay ever since version 8. Is there anything I should do to enable it?
Hmm, it should be enabled on 3.015 – can you share a log?
http://logs.volumio.org/volumio/sFLUyBJ.html
Thanks for that, I don’t see anything apparent about airplay failing, the service seems to launch…
Can you debug a bit more with:
systemctl status shairport-sync
cat /lib/systemd/system/shairport-sync.service
journalctl -u shairport-sync
ps -ef | grep shairport-sync
PS: you might want to move your pihole installation to different pi :wink:
Thanks for taking time to check it.
The airplay did not work even without the pihole (it was working fine on ver 8 though). Now, even the pihole is playing up with the latest version. I might try fresh installation and give you the new log and the debuging result. I will do it over the weekend when I am free.
Thank you
Edit:
Here is the new log from fresh install. No airplay still.
http://logs.volumio.org/volumio/y82gMzS.html![image|689x318](upload://dXEE9qw08rNETwaIIdcNMFmgbHk.jpeg)
Ah, not sure why it’s picking up the service from /etc/init.d/shairport-sync.
Can you try manually creating /lib/systemd/system/shairport-sync.service?
# How many services do we have?
systemctl list-units | grep shairport
which shairport-sync
# Should be /usr/bin/shairport-sync
# Fetch the service file
sudo wget https://raw.githubusercontent.com/volumio/Build/volumioOS/volumio/lib/systemd/system/shairport-sync.service -O /lib/systemd/system/shairport-sync.service
# Confirm that it's in the there
systemctl daemon-reload
systemctl start shairport-sync
systemctl stop shairport-sync
# Now restart Volumio's Node Back end
systemctl restart volumio
PS: it’s easier if you copy paste from your terminal into code blocks (</> icon), rather than screenshots that can’t be accessed as text…
now it is showing this:
`volumio@volumio:~$ systemctl status shairport-sync                              ● shairport-sync.service - Shairport Sync - AirPlay Audio Receiver
   Loaded: loaded (/lib/systemd/system/shairport-sync.service; enabled; vendor p
   Active: failed (Result: exit-code) since Fri 2021-01-29 13:00:34 UTC; 4s ago
  Process: 1249 ExecStart=/usr/bin/shairport-sync --configfile=/tmp/shairport-sy
 Main PID: 1249 (code=exited, status=203/EXEC)
Jan 29 13:00:34 volumio systemd[1]: Started Shairport Sync - AirPlay Audio Recei
Jan 29 13:00:34 volumio systemd[1249]: shairport-sync.service: Failed to execute
Jan 29 13:00:34 volumio systemd[1249]: shairport-sync.service: Failed at step EX
Jan 29 13:00:34 volumio systemd[1]: shairport-sync.service: Main process exited,
Jan 29 13:00:34 volumio systemd[1]: shairport-sync.service: Failed with result '
lines 1-11/11 (END)
Could you post the outputs of these commands?
shairport-sync --version
here:
volumio@volumio:~$ which shairport-sync
/usr/local/bin/shairport-sync
volumio@volumio:~$ shairport-sync --version
3.3.6-OpenSSL-Avahi-ALSA-soxr-metadata-dbus-sysconfdir:/etc
volumio@volumio:~$ cat /lib/systemd/system/shairport-sync.service
[Unit]
Description=Shairport Sync - AirPlay Audio Receiver
After=sound.target
Requires=avahi-daemon.service
After=avahi-daemon.service
Wants=network-online.target
After=network.target network-online.target
[Service]
ExecStart=/usr/bin/shairport-sync --configfile=/tmp/shairport-sync.conf
User=shairport-sync
Group=shairport-sync
[Install]
volumio@volumio:~$
Ah, seems to be a miss match in the installation location of the old images, please try
sudo ln -s $(which shairport-sync) /usr/bin/shairport-sync
systemctl restart shairport-sync
thank you so very much
it works now
