Hi there, I bought a new Pi3 with a DAC+ which is connected through ethernet. First installed OSMC which worked OK.
Now I installed Volumio (last build) on the same (wiped) SD card with Etcher and it got stuck and leaves me with nothing but a “freezed” screen unfortunately. Tried to do a clean reinstall but ended up at the same issue (see below) which is shown on the screen. Powersupply is an official Ri one and shouldn’t be a problem. No USB devices connected. Tried to disable BT without any luck.
Tried all the things I could find through Google but seems that for most people it just works (I don’t even use a WiFi dongle). Can anyone point me into the right direction?
volumio@volumio:~$ dmesg
[7.494690] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 9.017841] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 15.117935] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 15.126926] brcmfmac: brcmf_add_if: ignore IF event
[ 15.137886] brcmfmac: power management disabled
[ 15.559016] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 46.561368] brcmfmac: power management disabled
[ 46.931917] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 46.938591] brcmfmac: brcmf_add_if: ignore IF event
