Hi there,
please correct me if this works as intended but on a vanilla install of Volumio 2.185 (build from the 3rd of June) the browser runtime at some point stops using the requested domain and instead uses an IP of the System. This may not be obvious if You are just using one interface but I want to be able to control the thing over a VPN and this breaks the UI.
Any ideas?
Thanks,
Kiriakos
PS: sorry if this has been discussed already, I tried searching but only got irrelevant results.
