I’m using A Raspberry with a HifiBerry.
Both are separated powered by a power supply of 2x9V 1.67A and converted to 2x5V 1,5A.
IR receiver in the lower right corner.
Green led in the front witch is responding to the remote control commands.
And connect by WiFi.
Could you share which PS design you used.
Also, are you using any specific remote to control IR port? What are the functions controlled by remote?
Thanks!
I’m using the remote of my old CD player.
Using the commands: play, pause, next, previous, stop and power off
When a command is received the led flashes.
Thanks. At the input of the box it’s 2A and at the 2x9 volt output I’m using two 250ma fuses. These numbers are provided by the manual of the toroidal transformer.
I’m not an expert in electronics. I will try to make a schematic of the wiring.
