I’m using the latest version of the Volumio 3.3 app for Android. The last update of this application caused the inability to use screen rotation. At the moment, the application is displayed only in a vertical position. If I rotate the tablet to a horizontal position, the screen does not rotate. Of course, the screen rotates correctly in other applications and is not locked in the system tray. The question is whether it is an error in the application or a special action? If there is an error, please fix it. I operate Volumio with a tablet that is oriented in a horizontal stand. If this was a deliberate action of the programmers and the rotation of the screen was deliberately blocked in one position, please allow you to unlock this function.
Hi Mariusz,
At the moment, the display is locked in vertical orientation to ensure a better user experience. However, I can report your request to the developer.
Davide
VOLUMIO TECH SUPPORT
new app version is available for download
It unlocks the horizontal rotation ![]()
Best
Davide
hello,
With new version 3.742 the display is locked
best regards
The screen rotation is controlled by the app version, not the software version. Please ensure that you are using the latest version of the app from the app store.
If you encounter any further issues, please raise a ticket HERE
Davide
Hi…
I downloaded the last App version for Android from play store (3.3 (23.10.24)) and the display is only vertikal ….
It said ‚fix landscape view freeze‘
Do I have to set something ? The screen orientation is set to ‚auto‘
Thanks for you’re help
Still the latest version on android is vertical only.
Is it possible to provide a link to an older version that has auto rotate, or add a switch within the app for this function as i used to use landscape in preference particularly for the volume function?
